CNC Series
0i-F Plus
The FANUC CNC Series 0i-F Plus provides the ideal solution for basic multiple control applications. To maximize productivity on more specific applications, the controls can be easily customized using a wide range of additional functions. The FANUC CNC Series 0i-F Plus keeps the unbeatable performance and reliability of its predecessor, but includes new user-friendly features!
Products in 0i-F Plus Series
Milling
Cnc turning feature image
Turning
CNC turning solutions from FANUC America will cut costs by increasing productivity. Learn all about high speed CNC turning with feature rich CNC.
Grinding
CNC grinding uses highly controlled abrasive motion to remove microscopic material, achieving ultra-tight tolerances, smooth finishes, and precise geometries with exceptional repeatability.
Punching
CNC punch presses use precise, high-speed control to efficiently create holes, shapes, and forms in sheet metal with exceptional accuracy and repeatability.
FANUC 0i-F Plus CNC Demonstration
An overview of FANUC’s Zero i-F Plus CNC, highlighting multi-axis machining capability, iHMI usability, and conversational programming for machining.
FANUC CNC Series 0i-F Plus - Features and Benefits
Enhanced Safety
Integrated is FANUC’s Dual Check safety function.
Highly Customizable
Functions for simple customization included.
Improved Processing Power
Maximum look-ahead blocks 400.
Shop Floor Programming
Conversational programming via MANUAL GUIDE i.
High Performance
Integrated high-speed PMC.
Additional Functions Available
High-speed and high-quality machining package.
We'll help you find the best FANUC CNC to fit your needs.
Fanuc service irvision 2
Efficient FANUC Service Worldwide
Wherever you need us, we're available to provide sales, support and customer service all over the world. You can be sure to have access to a local contact who speaks your language. From pre-sale to integration and maintenance support, we're here to support your mobile robot integration from start to finish.
